[GRASS-user] Problem deleting raster created from point file using	v.to.rast
    SWAPAN GHOSH
    swap.ghsh at gmail.com
    Sun Mar 10 00:11:01 PST 2013
*Dear all,*
I am using the command like-
v.to.rast --overwrite input=Temp_Aug_86 at PERMANENT type=point
output=Rast_Temp_Aug_86 column=Rain14
Rast_Temp_Aug_86 at PERMANENT is created successfully.
But when I want to delete this raster using command like-
g.remove rast=Rast_Temp_Aug_86 at PERMANENT
Then I get an error like below-
*Removing raster <Rast_Temp_Aug_86 at PERMANENT>
fcell: couldn't be removed*
I am also trying this by running " g.remove -f
rast=Rast_Temp_Aug_86 at PERMANENT " but same problem arises.
Please give me some solution to recover this problem.
*Thanks & Regards,
Swapan*
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130310/dbd1c08b/attachment.html>
