[GRASS-user] r.resamp.rst error : "Not enough disk space--cannot write files"
bidon sanshuile
piano_bo at hotmail.com
Sun Mar 10 00:33:14 PST 2013
Hello,
I'm in an internship for a marine institute and try to calculate the sandwaves migration rate.
Everything was ok until today. I am confronted to a difficulty I cannot manage.
When I try to use the tool "r.resamp.rst", it gives me as answer:
r.resamp.rst input=map at PERMANENT ew_res=11 ns_res=11 pcurv=curv
Processing all selected output files will require
261320 bytes of disk space for temp files.
Temporarily changing the region to desired resolution ...
Changing back to the original region ...
Percent complete:
interpolate() failed
dnorm in mainc after grid before out1= 12.961481
ERROR: split_and_interpolate() failed
I have 14GB left on my hard disk so I don't understand why they are saying me that :/
I tried to find solution, and I found some answers (e.g. here : http://lists.osgeo.org/pipermail/grass-dev/2005-April/018152.html)
but I dont understand ^^
They speak about a "ulimit -f" function, but where should I write it ? It doesn't work in GRASS.
I am on windows, maybe is that the problem.
SO in conclusion, I am more than lost so if someone could help me it would be perfect!
Thank you,
b.raoul
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130310/7eb83561/attachment.html>
