[GRASS-user] r.resamp.rst error : "Not enough disk space--cannot write files"
bidon sanshuile piano_bo at hotmail.com
Sun Mar 10 15:28:10 PDT 2013
> Date: Sun, 10 Mar 2013 20:24:08 +0100
> Subject: Re: [GRASS-user] r.resamp.rst error : "Not enough disk space--cannot write files"
> From: markus.metz.giswork at gmail.com
> To: piano_bo at hotmail.com
> CC: grass-user at lists.osgeo.org
> On Sun, Mar 10, 2013 at 7:41 PM, bidon sanshuile <piano_bo at hotmail.com> wrote:
> >> Date: Sun, 10 Mar 2013 16:28:49 +0100
> >> On Sun, Mar 10, 2013 at 9:33 AM, bidon sanshuile <piano_bo at hotmail.com>
> >> wrote:
> >> > Hello,
> >> > I'm in an internship for a marine institute and try to calculate the
> >> > sandwaves migration rate.
> >> > Everything was ok until today. I am confronted to a difficulty I cannot
> >> > manage.
> >> > When I try to use the tool "r.resamp.rst", it gives me as answer:
> >> > r.resamp.rst input=map at PERMANENT ew_res=11 ns_res=11 pcurv=curv
> >> > Processing all selected output files will require
> >> Note that this message:
> >> > 261320 bytes of disk space for temp files.
> >> is bogus for large regions with fine resolution because of integer
> >> overflow (fixed in trunk).
> >> How many cells are in your current region with resolution=11?
> > Thank you for your answers!
> > Here are the characteristics of the raster:
> >  |   Rows:         3062
> >  |   Columns:      2587
> >  |   Total Cells:  7921394
> > I don't know how many of these have a resolution of 11.
> You need to provide the output of g.region -p. Note that all cells
> have the same resolution, and that r.resamp.rst is typically used to
> resample to a finer resolution, e.g. 20 to 10 map units.
Here is the result:
projection: 0 (x,y)
zone:       0
north:      5682231.5
south:      5679169.5
west:       469641.5
east:       472228.5
nsres:      1
ewres:      1
rows:       3062
cols:       2587
cells:      7921394
I must admit that I am quite new in GRASS, and I don't master all the concepts. Is the raster too big? Do I have to increase the memory allocated? In this last case, I don't know at all which module to use.
> > . I am following a
> > step by step manual where they advise to set ew_res at this value.
> Why 11 and not 10?
It doesn't work for both ^^ It works until I put 7, but I would like to make it as written in the manual, to be precise enough.
> Markus M
> >>> What filesystem? FAT32 cannot support files larger than 4 GiB; NTFS
> >>> shouldn't have any problems.
> > My two hard discs are NTFS
> >> > Temporarily changing the region to desired resolution ...
> >> > Changing back to the original region ...
> >> > Percent complete:
> >> > interpolate() failed
> >> > dnorm in mainc after grid before out1= 12.961481
> >> > ERROR: split_and_interpolate() failed
> >> > I have 14GB left on my hard disk so I don't understand why they are
> >> > saying
> >> > me that :/
> >> > I tried to find solution, and I found some answers (e.g. here :
> >> > http://lists.osgeo.org/pipermail/grass-dev/2005-April/018152.html)
> >> > but I dont understand ^^
> >> > They speak about a "ulimit -f" function, but where should I write it ?
> >> > It
> >> > doesn't work in GRASS.
> >> > I am on windows, maybe is that the problem.
> >> > SO in conclusion, I am more than lost so if someone could help me it
> >> > would
> >> > be perfect!
> >> > Thank you,
> >> > b.raoul
> >> > _______________________________________________
> >> > grass-user mailing list
> >> > http://lists.osgeo.org/mailman/listinfo/grass-user
-------------- section suivante --------------
Une pi?ce jointe HTML a ?t? nettoy?e...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130310/db1cce1e/attachment.html>
