[GRASS-user] ps.map: rectangle over map border?
Nikos Alexandris
nik at nikosalexandris.net
Mon Mar 11 06:18:56 PDT 2013
Hi Moritz :-)
It doesn't work for me :-(.
Nikos A:
> > In ps.map,
> > is it (not) possible to overlay a color-filled rectangle, which exceeds
> > the map frame/border, and by doing so, it should be on top of the border?
That is "my English is pretty bad :-/" because I mean(t) that the rectangle
crosses the map's border.
> > Currently, no matter what I try, the map border is drawn on top of the
> > rectangle (within which I have placed a color table/legend).
> > The colortable does not feature a background option (according to the
> > manual -- blindly tested as well)!?
> > Is there a trick to overcome this problem? (--yes, I want to break the
> > convention of being inside the map frame)
Moritz L:
> AFAIK, just give the rectangle map coordinates that are outside the map
> frame. Ex:
> raster elevation at PERMANENT
> rectangle 637375 211190 643918 207236
note, the manual states:
rectangle east north east north -- typo?
> color black
> fcolor red
> width 2.0
> end
> with r.info -g elevation:
> north=228500
> south=215000
> east=645000
> west=630000
So, that means that it is:
rectangle west north east south?
What about the following:
did you try to place a box that is 1/3 inside the map-frame and 2/3 outside?
The map border is drawn on top of the rectangle.
The case here is that the class labels are too long to fit outside of the map-
frame. Squeezing the colortable outside will make them hard to read.
Shrinking the map-frame is not an option -- the map is anyway kind of an
overview map -- lots of details will be lost.
Best, N
Desc: This is a digitally signed message part.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130311/7defb6ea/attachment.pgp>
