[GRASS-user] ps.map: rectangle over map border?
    Vincent Bain
    bain at toraval.fr
    Mon Mar 11 06:57:19 PDT 2013
Hello Nikos,
Not sure to understand your issue, so my answer might be off-target :
perhaps you can have a look at the output ps file. If it's only a matter
of display order, you can rearrange successive instructions within the
file in order to have your background laying over the border.
V.
Le lundi 11 mars 2013 à 15:18 +0200, Nikos Alexandris a écrit :
> Hi Moritz :-)
> It doesn't work for me :-(.
> Nikos A:
> > > In ps.map,
> > > is it (not) possible to overlay a color-filled rectangle, which exceeds
> > > the map frame/border, and by doing so, it should be on top of the border?
> That is "my English is pretty bad :-/" because I mean(t) that the rectangle
> crosses the map's border.
> > > Currently, no matter what I try, the map border is drawn on top of the
> > > rectangle (within which I have placed a color table/legend).
> > > The colortable does not feature a background option (according to the
> > > manual -- blindly tested as well)!?
> > > Is there a trick to overcome this problem? (--yes, I want to break the
> > > convention of being inside the map frame)
> Moritz L:
> > AFAIK, just give the rectangle map coordinates that are outside the map
> > frame. Ex:
> > raster elevation at PERMANENT
> > rectangle 637375 211190 643918 207236
> note, the manual states:
> rectangle east north east north -- typo?
> >      color black
> >      fcolor red
> >      width 2.0
> >      end
> > with r.info -g elevation:
> > north=228500
> > south=215000
> > east=645000
> > west=630000
> So, that means that it is:
> rectangle west north east south?
> What about the following:
> did you try to place a box that is 1/3 inside the map-frame and 2/3 outside?
> The map border is drawn on top of the rectangle.
> The case here is that the class labels are too long to fit outside of the map-
> frame.  Squeezing the colortable outside will make them hard to read.
> Shrinking the map-frame is not an option -- the map is anyway kind of an
> overview map -- lots of details will be lost.
> Best, N
> _______________________________________________ grass-user mailing list grass-user at lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/grass-user
