[GRASS-user] ps.map: rectangle over map border?
Nikos Alexandris
nik at nikosalexandris.net
Mon Mar 11 07:31:00 PDT 2013
Vincent Bain wrote:
> Not sure to understand your issue, so my answer might be off-target :
Reading the following, I think you do.
> perhaps you can have a look at the output ps file. If it's only a matter
> of display order, you can rearrange successive instructions within the
> file in order to have your background laying over the border.
FWIW, I tried that in the ps.map script itself, i.e., first the border and then
the rectangle. Doesn't this affect the display order? Will try later to edit
the ps file.
Thank you, Nikos
[rest deleted]
Desc: This is a digitally signed message part.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130311/ce665215/attachment.pgp>
