[GRASS-user] Fwd: Airborne LiDAR data strip adjustment
Hamish
hamish_b at yahoo.com
Fri May 17 05:42:37 PDT 2013
> Ok, I just found out that this is not necessary! My data are
> already pre-processed, so it's applied strip adjustment. I have
> to divide it into subsets and merge the data, because now it's
> in form of strips. I guess the right method is using 'g.region'
is the data as raster maps (merge overlaps with r.series/r.patch)
or a series of points? (for points, 'v.in.ascii -bt' or r.in.xyz)
see http://grass.osgeo.org/wiki/LIDAR
Hamish
