[GRASS-user] Fwd: Airborne LiDAR data strip adjustment
Adrian Kirilov
kirilov.adrian at gmail.com
Fri May 17 07:34:02 PDT 2013
It's a series of points. But how can I export them from all imported files
(strips) later into a single one ASCII file into specific region? I think
that v.out.ascii for example is only for exporting single file. And I need
to export multiple, falling into the region. Is this possible in GRASS?
On Fri, May 17, 2013 at 2:42 PM, Hamish <hamish_b at yahoo.com> wrote:
> > Ok, I just found out that this is not necessary! My data are
> > already pre-processed, so it's applied strip adjustment. I have
> > to divide it into subsets and merge the data, because now it's
> > in form of strips. I guess the right method is using 'g.region'
> is the data as raster maps (merge overlaps with r.series/r.patch)
> or a series of points? (for points, 'v.in.ascii -bt' or r.in.xyz)
> see http://grass.osgeo.org/wiki/LIDAR
> Hamish
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130517/71c698ed/attachment.html>
