[GRASS-user] v.in.gshhs
Nicolas Pérenne
nicolas.perenne at free.fr
Tue May 21 03:51:52 PDT 2013
Le 20/05/2013 21:18, Nicolas Pérenne a écrit :
> Hi,
> Trying to import GSHHG V2.2.2 ( see
> http://www.soest.hawaii.edu/pwessel/gshhg/ ) through 'v.in.gshhs', I
> ran into this:
> GRASS 6.4.2 (wgs84):~/tmp/gshhs_bin > v.in.gshhs gshhs_c.b out=gshhs_c
> Using lat/lon bounds N=90.000000 S=-90.000000 E=180.000000 W=-180.000000
> ERREUR :Trying to import version 3, only GSHHS versions 4 to 8 (2.0)
> are supported.
> which looks strange to me. I am currently doing some 'v.in.ogr' on the
> Shapefile version of GSHHS, but the process appears to be quite long
> for the "high" and "full" resolution (assuming one wants to import the
> whole dataset without using '-c'), so I was hoping 'v.in.gshhs' would
> be quicker... please let me know if this is a known issue, or
> something I did wrong, etc.
> Nicolas
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
I assume GSHHG internal version numbers are just not ordered by
increasing value... anyway using '-r' to restrict the import of a GSHHG
__shapefile__ to the current Grass region works just fine (including the
highest GSHHS resolution): sorry for the inconvenience!
Nicolas
