[GRASS-user] v.in.gshhs
Markus Metz
markus.metz.giswork at gmail.com
Tue May 21 04:59:16 PDT 2013
On Mon, May 20, 2013 at 9:18 PM, Nicolas Pérenne
<nicolas.perenne at free.fr> wrote:
> Hi,
> Trying to import GSHHG V2.2.2 ( see
> http://www.soest.hawaii.edu/pwessel/gshhg/ ) through 'v.in.gshhs', I ran
> into this:
> GRASS 6.4.2 (wgs84):~/tmp/gshhs_bin > v.in.gshhs gshhs_c.b out=gshhs_c
> Using lat/lon bounds N=90.000000 S=-90.000000 E=180.000000 W=-180.000000
> ERREUR :Trying to import version 3, only GSHHS versions 4 to 8 (2.0) are
> supported.
The current GSHHG data release number is 9, the current GSHHG data
version number is 2.2.2, and the current GSHHG software version is
1.13. v.in.gshhs has been updated with r56356 to support the latest
release. In contrast to v.in.ogr, v.in.gshhs imports the shorelines as
lines, not sure if this is what you want.
Markus M
> which looks strange to me. I am currently doing some 'v.in.ogr' on the
> Shapefile version of GSHHS, but the process appears to be quite long for the
> "high" and "full" resolution (assuming one wants to import the whole dataset
> without using '-c'), so I was hoping 'v.in.gshhs' would be quicker... please
> let me know if this is a known issue, or something I did wrong, etc.
> Nicolas
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
