[GRASS-user] Announcing Emacs grass-mode.el version 0.2
R.S. Bhalla
rsbhalla at gmail.com
Mon Nov 4 19:16:23 PST 2013
Thank you for this Tyler,
Will certainly take it for a spin.
I've been using spgrass6 and ESS for a while.
Cheers,
Ravi
On 11/05/2013 04:57 AM, Tyler Smith wrote:
> Nick Ves <vesnikos at gmail.com> wrote:
>>> Features:
>>> * Run grass as an inferior process inside an Emacs buffer
>>> * Tab-completion of GRASS commands, arguments, flags and map names
>> autocompletion of map names is by far the most welcoming feature!
> Glad to hear it! It wil also work for commands that import maps from other locations. E.g., v.proj - after you've entered the 'location' value, it will use that directory to complete the 'input' map name.
> These little tweaks are not automatic - I have to add a line for each case. So if you find something that isn't completing as it should, let me know.
> Best,
> Tyler
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
