[GRASS-user] Export multiple rasters into a single textfile
Werner Macho
werner.macho at gmail.com
Wed Nov 20 05:15:59 PST 2013
Hi!
gdal2xyz.py from gdal has a -csv switch
(Though never tested the -csv by myself, but the script itself works nicely)
It is not exactly what you want but might be a start if no one else
comes up with a GRASS solution.
should be doable to create a script that integrates gdal2xyz and
combines the values afterwards..
kind regards
Werner
On Wed, Nov 20, 2013 at 3:00 PM, Johannes Radinger
<johannesradinger at gmail.com> wrote:
> Hi,
> what is the fastest/most convenient way to export multiple rasters into a
> simple single text file (e.g. csv) so that the rows represent the single
> cells and the columns the values of the single rasters at that specific
> cell? The rasters (n=12) have all the same resolution and consist of each
> appr. 250000 cells.
> What came into my mind was to generate a point-vector (center points of each
> raster cell) and then query all rasters at the locations of these points
> (250000) but I think there must be a more direct way available in GRASS?
> Any ideas?
> /Johannes
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
