[GRASS-user] Tessellation of a set of polygons
Moritz Lennert
mlennert at club.worldonline.be
Mon Sep 2 06:13:10 PDT 2013
On 29/08/13 17:38, Thomas Leduc wrote:
> Let's consider a set of input polygons (represented by dark gray
> polygonal footprints in the enclosed screenshot [1]). I wonder whether
> there already exists a (set of) GRASS instructions to produce the
> "surrounding tessellation". I mean, could you please tell me how to
> compute the set of multicolor polygons in the enclosed screenshot?
> As an example, the blue polygon is the set of points that are:
> - overlayed by the dark gray polygon labeled #1
> - or closer to the dark gray polygon labeled #1 than to any other
> input polygon.
> Thanks a lot for any help/advice.
You could try the following workflow:
- add category values to your boundaries (if that is important make them
equal to the cat values of your centroids, otherwise just using
v.category op=add type=boundary)
- use v.to.points to transform the boundaries to points (each point will
have the cat value of the corresponding boundary)
- v.voronoi to create voronoir diagrams for these points
- v.dissolve to disolve boundaries between polyons with the same
category numbers
Moritz
