[GRASS-user] Installing addon's using g.extension on Mac OSX 10.7.5?
William Kyngesburye
woklist at kyngchaos.com
Fri Jan 31 21:33:17 PST 2014
g.extension should work. The main key is that you need to install the Xcode command line tools. This can be done either from the Xcode app (free from app store), or by downloading the command line tools installer separately (from an Apple developer account).
The old "modbuild" thing could still work but g.extension is better. The readme mentioned is probably the modbuild readme, which doesn't help you with g.extension.
On Jan 31, 2014, at 7:50 PM, Jens Hegg wrote:
> I am pretty new to GRASS but I seem to be slowly getting myself wrapped around how to work it. Unfortunately I could really use the r.stream addons but can't seem to install them. I've tried every way I can think of to run g.extension both through the qGIS GRASS command as well as in standalone GRASS 6.4.3. I get "ERROR: The 'make' program is required. Please install first."
> I've found a thread on here from Oct 2013 saying that this issue was, at one time, fixed for someone running OSX 10.8 (http://lists.osgeo.org/pipermail//grass-user/2013-October/069133.html) and looking at the development wikis there are some bug reports about this error but I can't figure out conclusively whether they are fixed.
> I've found this blog post showing a way to modify the modules directory so that addons can be added but it is older than the email thread and I wanted to get input before I start modifying things based upon it. (http://digitalelevation.wordpress.com/2012/06/07/installing-grass-add-ons-on-mac-osx/). There is also mention in the email thread above that there is a readme file with instructions on how to compile addons for OSX but that readme isn't included in the Kyngchaos.com download as mentioned and I can't otherwise seem to find it.
> Any help or advice would be much appreciated!
> Thanks, Jens Hegg
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
