[GRASS-user] r.stream.basins disappeared?
Johannes Radinger johannesradinger at gmail.com
Mon Jun 16 05:22:41 PDT 2014
On Mon, Jun 16, 2014 at 2:09 PM, Margherita Di Leo <diregola at gmail.com>
wrote:
> Hi Johannes,
> On Mon, Jun 16, 2014 at 1:50 PM, Johannes Radinger <
> johannesradinger at gmail.com> wrote:
>> Hi all,
>> I recognized that the r.stream.* suit was moved from the add-on arena to
>> the main code of GRASS7, but what happened to r.stream.basins. This tool
>> (which I depend on in my own
>> add-on) is neither available in the main GRASS7 nor as an G7 add on.
> AFAIK it is in addons [1]. Have you experienced any problems in fetching
> it? There is a ticket [2] and a discussion [3] about moving it to trunk or
> not, but as you can see from the discussion, MMetz has raised some doubts
> regarding the code, thus at the moment it remains in addons.
Oh thank you, of course it is part of the add-ons. Sorry. I just was
confused as all other r.stream modules are already part of the main code.
So for the moment I'll install it as add-on. Thank you again!
> HTH,
> madi
>>  Has the functionality been merged with another tool? I basically need to
>> delineate the part of a catchment which is upstream a certain pair of
>> coordinates. This could be easily calculated with r.stream.basin by
>> providing the coordinate pair and the flow direction map. The output was a
>> raster map showing the upstream catchment.
>> Any help is appreciated...
>> Best regards,
>> Johannes
>> [1]
> https://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.stream.basins
> [2] https://trac.osgeo.org/grass/ticket/2237
> [3]
> Best regards,
> Dr. Margherita DI LEO
>  Scientific / technical project officer
> European Commission - DG JRC
> Institute for Environment and Sustainability (IES)
> Via Fermi, 2749
> I-21027 Ispra (VA) - Italy - TP 261
> Tel. +39 0332 78 3600
> margherita.di-leo at jrc.ec.europa.eu
> Disclaimer: The views expressed are purely those of the writer and may not
> in any circumstance be regarded as stating an official position of the
> European Commission.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140616/8c71164b/attachment.html>
