[GRASS-user] ps.map - eps frame affect/hide border and legend
Domenico Giusti
dncgst at gnewarchaeology.it
Fri Mar 7 04:58:48 PST 2014
The frame is inside the map region.
I cleaned the eps frame with eps2eps. But now I think it is a ps reader
problem:
* with gv no problems with the eps frame (clean and no-clean)
* with evince problems only with the no-clean eps frame. No stderr
differences between clean and no-clean ps, launching evince from the
cli.
Thank you very much!
On gio, 2014-03-06 at 22:06 -0800, Hamish wrote:
> Domenico wrote:
> > I'm trying to output a ps file with ps.map (GRASS 6.4.2). Results from
> > the psmap.def are good, with border, colortable, vlegend, etc..
> > http://osgeo.codepad.org/NtM3oJy0 (pasted def file)
> > But when I add an eps frame border, colortable and vlegend disappear.
> > I changed the order, putting eps before or after the vlegend
> > instruction, but without successful.
> Hi,
> could you post a bug in the trac system? an example made using one of the standard grass datasets (Spearfish or North Carolina) would help a lot too.
> is the eps file inside or outside the map frame? sometimes it helps to move it.
> the used-added eps file is just copied verbatim within the final output file; it might help to keep it simple or clean with eps2eps first?
> did you put a final 'end' after all the ps.map instructions?
> thanks,
> Hamish
Domenico Giusti <dncgst at gnewarchaeology.it>
GPG keyID: 2048R/A3AB7054F6E5D778
