[GRASS-user] 6.5svn Build Problem
Rich Shepard
rshepard at appl-ecosys.com
Fri Mar 28 10:49:36 PDT 2014
On Fri, 28 Mar 2014, Vaclav Petras wrote:
> wxversion is a usually a separate package. The reason is that it access
> all the other versions.
Vaclav,
It is quite difficult to find wxpython.py. There's no SlackBuild.org
version and a Web search finds references to using it on wxpython's wiki and
PyPi, but no module source to install. Since I use only one version of
wxPython here is there a --disable option in the configuration to eliminate
it?
> The 6.5 is not working for you either, so I would try GRASS 7 (beta)
> again. Moreover, recently there was a change which might improve the
> build in gui/wxpython/ subdirectories. Also note that if the build fails
> there, it does not necessary mean that tit will not work at all (it just
> behave strangely sometimes).
Until yesterday 6.5 built without error for several years. GRASS-7.0 keeps
failing to build, probably because there's no wxversion here.
> Which system are you using anyway?
Slackware-14.1.
Rich
