[GRASS-user] grass6.4.4 start up scripts issue
Huidae Cho
grass4u at gmail.com
Wed Oct 8 07:40:33 PDT 2014
Hi Dr. Srini,
This is Cho. I just tried 6.4.4, but I didn't get any errors. You can try
the following:
1. Open a new cmd window.
2. Run "C:\OSGeo4W\apps\grass\grass-6.4.4\bin\g.proj.exe --help" and you
should get a library error.
3. Run "C:\OSGeo4W\bin\grass64.bat -wx" and Control+C to terminate the
process.
4. Run "C:\OSGeo4W\apps\grass\grass-6.4.4\bin\g.proj.exe --help" and this
time you should see a help message.
5. Typing "echo %ERRORLEVEL%" should return 0.
Let me know what you get.
Regards,
Huidae
On Wed, Oct 8, 2014 at 7:31 AM, R Srinivasan <r-srinivasan at tamu.edu> wrote:
> I just installed the OSGeo4W packages inlcuding grass 6.4.4 and qgis etc
> when try to start the grass using grass64.bat -wx in a command window
> it brings the welcome window where I selected the mapset and location etc.
> then click on start grass button, the program flashes starting grass gui
> and then a message on my cmd window
> GRASS module 'g.proj' not found. Unable to start map display window
> and the program closes.
> has anyone found a solution for this issue.
> thanks.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141008/eb6f7661/attachment-0001.html>
