[GRASS-user] Unable to use Command Line Access to GRASS-GIS
Pietro
peter.zamb at gmail.com
Fri Oct 31 01:46:15 PDT 2014
Dear Artur
On Thu, Oct 30, 2014 at 10:55 PM, Artur Bercik <vbubbly21 at gmail.com> wrote:
> Dear GRASS-GIS users:
> I wanted to use GRASS-GIS through command line access in my Windows PC.
> So, I have installed GRASS GIS 7.0.0beta3 in drive C of my PC.
> But, when I enter the following command in the windows command prompt:
> "C:\Program Files (x86)\GRASS GIS 7.0.0beta3\bin\i.cluster.exe"
> the program can't start because libint-8.dll is missing from your computer.
> Try reinstalling the program...
> Please help me what should I do to have the command line access to
> GRASS-GIS.
If you want to use GRASS without caling GRASS explicity you have to
set your environment variables correctly.
At work one colleague use this bat files to set the variable and use
another python interpreter than the default one:
rem => grass70b2 using python XY
set GISBASE=C:\GRASS GIS 7.0.0beta2
rem => add a environmental variable for pythonxy
set PY_XY=C:\Python27
rem => reading the env file for pxthonxy
call "%GISBASE%\etc\env_xy.bat"
cd C:\GRASS GIS 7.0.0beta2\etc\gui\scripts
cd "%USERPROFILE%"
"%GRASS_PYTHON%" "%GISBASE%\etc\grass70.py" %C:\Users\<<your
user>>\Documents\grassdata\<<location>>\<<mapset>>
if %ERRORLEVEL% GEQ 1 pause
and the env_xy.bat file contains
set GRASS_SH=%GISBASE%\msys\bin\sh.exe
set GRASS_HTML_BROWSER=firefox
rem GRASS_PYTHON=%GISBASE%\extrabin\python.exe
set GRASS_PYTHON=%PY_XY%\python.exe
rem PYTHONHOME=%GISBASE%\Python27
set PYTHONHOME=%PY_XY%
set GRASS_PROJSHARE=%GISBASE%\share\proj
set PROJ_LIB=%GISBASE%\share\proj
set GDAL_DATA=%GISBASE%\share\gdal
set GEOTIFF_CSV=%GISBASE%\share\epsg_csv
set PATH=%GISBASE%\msys\bin;%PATH%
set PATH=%GISBASE%\extrabin;%PATH%
set PATH=%GISBASE%\bin;%PATH%
I hope this could help to solve your problem.
Pietro
