[GRASS-user] help with batch exporting r.out.gdal
Rajat Nayak rajat27404 at gmail.com
Wed Sep 3 23:00:51 PDT 2014
Thank you Tom for the mail.
I'm still unable to get it working. Some smaller cliche I guess,
will try again.
Regards
Rajat Nayak
On Tue, Sep 2, 2014 at 6:50 PM, Thomas Adams <tea3rd at gmail.com> wrote:
> Rajat,
> I assume you are running this at the GRASS prompt? If not, you must do
> this. Also, if you don't provide the full path for 'NPPFILES', you should
> run the command from the directory where 'NPPFILES' is located.
> Additionally, you may want to change your code to this:
> for files in $(cat NPPFILES); do
> echo $files;
> r.out.gdal input="$NPPFILES" output="$NPPFILES.tiff" format=GTiff ; done
> You may want to include the line "echo $files;" to see if the individual
> map names are being read correctly
> Regards,
> Tom
> On Tue, Sep 2, 2014 at 8:57 AM, Rajat Nayak <rajat27404 at gmail.com> wrote:
>> Dear All,
>> I just created a list of files (NPPFILES) using g,mlist command in
>> grass7.
>> Now I would like to export these files as .tiff files.
>> I tried this command
>> for files in $NPPFILES; do
>> This is not working for me. I tried giving directory path, still no
>> result.
>> I will be grateful if anybody can help me with this.
>> Thanking you,
>> Regards
>> Rajat Nayak
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140904/bd2c4a93/attachment.html>
