[GRASS-user] help with batch exporting r.out.gdal
Nikos Alexandris nik at nikosalexandris.net
Thu Sep 4 00:09:45 PDT 2014
Rajat Nayak <rajat27404 at gmail.com> wrote:
> >> I just created a list of files (NPPFILES) using g,mlist command in
> >> grass7. Now I would like to export these files as .tiff files.
> >> I tried this command
> >> for files in $NPPFILES; do
> >> r.out.gdal input="$NPPFILES" output="$NPPFILES.tiff" format=GTiff ; done
Here, you ask the string "files" to get each of the whatsoever values
are stored inside the variable $NPPFILES.
1. is there an NPPFILES variable defined already?  Something like
NPPFILES="
file_1
file_2
flie_3"
2. What you actually need to feed the "input=" parameter, is the "files"
term, not the "$NPPFILES".
> >> This is not working for me. I tried giving directory path, still no
> >> result.
ok, assuming you are running this from inside a GRASSy session, you
should be, at the time of executing the for loop, inside the directory
where the "list of files" is also present.  I guess you created a file,
say "nppfiles_list".
To be sure, just instruct
cat nppfiles_list
and expect to get the list of files you created.
If that's ok, then it should work, e.g.:
for File in `cat nppfiles_list`; do r.out.gdal input=${File}
output=${File}.tiff; done
Note, instead of "File" it could be any other string you like.
Hope this helps a bit.
Nikos
