[GRASS-user] raster exchange between GRASS and R with nodata
Nuno Sá
nunocesardesa at gmail.com
Thu Sep 4 06:38:26 PDT 2014
Hello!
Did you try this one?
*r.out.gdal etc nodata*=*'NA'*
On 4 September 2014 14:27, Johannes Radinger <johannesradinger at gmail.com>
wrote:
> Hi all,
> of course it is possible to load the raster maps directly via spgrass6.
> However, we use this work
> flow also to exchange some of the maps between different users (e.g. via
> email) and to permanently
> store single files (geotiffs that contain the proj information within the
> file). So, I agree that using spgrass6 would be much more efficient, but
> I'll stick to exporting to geotiffs and so I need to solve the issues with
> NA's.
> /Johannes
> On Thu, Sep 4, 2014 at 2:31 PM, Thomas Adams <tea3rd at gmail.com> wrote:
>> Johannes,
>> If you want to read your file into R, there is no need to export your map
>> from GRASS to do this. Simply install and use the R contributed package
>> 'spgrass6' (spgrass6 has R dependencies that need to be installed first);
>> it works wonderfully:
>> Within GRASS, at the GRASS terminal prompt...
>> > library(spgrass6)
>> Loading required package: sp
>> Loading required package: XML
>> GRASS GIS interface loaded with GRASS version: GRASS 7.0.0beta3 (2014)
>> and location: ohrfc_mpe
>> > dat<-readRAST6("xmrg0101200306z")
>> > image(dat)
>> This is far more efficient.
>> Tom
>> On Thu, Sep 4, 2014 at 5:32 AM, Johannes Radinger <
>> johannesradinger at gmail.com> wrote:
>>> Hi,
>>> I want to export a raster map (FCELL) from GRASS70 to the geotiff format
>>> using r.out.gdal and to import it later on in R. The map contains many no
>>> data values.
>>> Here some details about the raster:
>>> Type of Map: raster Number of Categories: 0
>>> Data Type: FCELL
>>> Rows: 750
>>> Columns: 750
>>> Total Cells: 562500
>>> total null and non-null cells: 15105636
>>> total null cells: 15105047
>>> So when I export the map, r.out.gdal reports: "Input raster map contains
>>> cells with NULL-value (no-data). The value -nan will be used to represent
>>> no-data values in the input map. You can specify a nodata value with the
>>> nodata option."
>>> When I subsequently try to import the geotiff into R (using the package
>>> 'Raster') the nodata values are not recognised as NA's:
>>> a <- raster("*.tif")
>>> summary(a)
>>> Min. 0.5294496
>>> 1st Qu. 0.7171210
>>> Median 0.7871540
>>> 3rd Qu. 1.1581826
>>> Max. 1.5494517
>>> NA's 0.0000000
>>> So I am wondering if I need to set any specific parameter during the
>>> export (r.out.gdal) or import (raster()).
>>> As I am not only exporting FCELL (Float32) raster but also multiple
>>> (N=500) other rasters to R I would be interested in a solution also for
>>> DCELL (Float64). Of course I can export all of as Float64 as the file size
>>> should not be a problem.
>>> Any suggestions or experiences of handling NA's during raster exchange
>>> between GRASS and R?
>>> /Johannes
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
Nuno César de Sá
+351 91 961 90 37
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140904/da83d744/attachment.html>
