[GRASS-user] how to tweak the parameters to speed up i.segment
Margherita Di Leo
diregola at gmail.com
Fri Sep 26 06:18:04 PDT 2014
Ciao Pietro!
On Fri, Sep 26, 2014 at 2:49 PM, Pietro <peter.zamb at gmail.com> wrote:
> Following this approach I've implement: i.segment.hierarchical
> (grass-addons). I've used this module to segment an image (RGB) of 24
> x 48 kpixels on my laptop in less than 12 hours (if I remeber
> correctly). Still I think we can reach greater improvement working at
> C level but I didn't have time to work on it I have just some ideas,
> no code.
> kudos! :-D
I have some troubles installing it though:
> g.extension i.segment.hierarchical
Fetching <i.segment.hierarchical> from GRASS-Addons SVN repository (be
patient)...
Compiling...
Makefile:17: warning: overriding commands for target
`/tmp/tmpc7e9Oc/i.segment.hierarchical/etc/i.segment.hierarchical/i.segment.hierarchical'
/space/gis/grass_trunk/grass-7.1.svn/include/Make/ScriptRules.make:19:
warning: ignoring old commands for target
File
"/tmp/tmpc7e9Oc/i.segment.hierarchical/scripts/i.segment.hierarchical",
line 158, in <module>
from isegpatch import rpatch_map
ImportError: No module named isegpatch
make: *** [i.segment.hierarchical.tmp.html] Error 1
ERROR: Compilation failed, sorry. Please check above error messages.
Thanks!
madi
Best regards,
Dr. Margherita DI LEO
Scientific / technical project officer
European Commission - DG JRC
Institute for Environment and Sustainability (IES)
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo at jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not
in any circumstance be regarded as stating an official position of the
European Commission.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140926/5f0993ab/attachment.html>
