[GRASS-user] conditional buffering with DEM
Ahmet Temiz
ahmettemiz88 at gmail.com
Thu Apr 23 07:44:44 PDT 2015
thank you Nikos
I meant that creating buffers from a line, which also querying DEM values.
DEM is in subquery position of buffer map
regards
On Thu, Apr 23, 2015 at 1:28 PM, Nikos Alexandris <nik at nikosalexandris.net>
wrote:
> * Ahmet Temiz <ahmettemiz88 at gmail.com> [2015-04-23 12:16:49 +0300]:
> > hello,
> > Which function can we use to generate a map that has conditional
> buffering
> > according to DEM from a line ?
> Hello Ahmet,
> I don't understand the "from a line" part of your question. Yet, I guess
> you mean to keep a specific range of DEM values.
> You can directly use r.mapcalc for such tasks.
> 1) Remember to set the extent and the resolution of the active
> computational region, it'll be also the one of the new map produced by
> r.mapcalc
> 2) r.mapcalc 'NewMap = if( DEM > 100 && DEM < 200, DEM, null())'
> This example will write only DEM values between '100 < DEM < 200' in the
> "NewMap" and will set to NULL all other pixels that don't satisfy the
> above expression. For more, please look at r.mapcalc's manual.
> Of course, all this is valid and achievable via the GUI.
> Regards, Nikos
Ahmet Temiz
Jeoloji Müh.
Afet ve Acil Durum Yönetimi Başkanlığı
Bilgi İşlem Dairesi Başkanlığı-CBS Grubu
________________________
Ahmet Temiz
Geological Eng.
Information Systems - GIS Group
Disaster and Emergency Management
of Presidency
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150423/0291c179/attachment-0001.html>
