[GRASS-user] Large vector file processing
Margherita Di Leo
diregola at gmail.com
Fri Apr 24 00:54:38 PDT 2015
I'm trying to vectorize a very large file
| Type of Map: raster Number of Categories: 255
| Data Type: CELL
| Rows: 88537
| Columns: 54410
| Total Cells: 4817298170
| Projection: Lambert Azimuthal Equal Area
| N: 4239550 S: 2026125 Res: 25
| E: 4284650 W: 2924400 Res: 25
| Range of data: min = 11 max = 255
using GRASS 7.1.svn (r65027)
:~ > r.to.vect input=raster_tty output=vector_tty type=area
Extracting areas...
100%
Writing areas...
100%
Building topology for vector map <vector_tty at assessment>...
Registering primitives...
Killed0000
what does this mean?
:~ > v.build vector_tty
WARNING: Coor file of vector map <vector_tty at assessment> is larger than it
should be (2403996039 bytes excess)
Killed0000
Question about "larger that it should be": What is this limitation? I guess
is related to the specs of my laptop?
Thanks,
Best regards,
Dr. Margherita DI LEO
Scientific / technical project officer
European Commission - DG JRC
Institute for Environment and Sustainability (IES)
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo at jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not
in any circumstance be regarded as stating an official position of the
European Commission.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150424/bfe61be3/attachment.html>
