[GRASS-user] Large vector file processing
Moritz Lennert
mlennert at club.worldonline.be
Fri Apr 24 01:09:27 PDT 2015
On 24/04/15 09:54, Margherita Di Leo wrote:
> Hi,
> I'm trying to vectorize a very large file
> | Type of Map: raster Number of Categories: 255
> | Data Type: CELL
> | Rows: 88537
> | Columns: 54410
> | Total Cells: 4817298170
> | Projection: Lambert Azimuthal Equal Area
> | N: 4239550 S: 2026125 Res: 25
> | E: 4284650 W: 2924400 Res: 25
> | Range of data: min = 11 max = 255
> using GRASS 7.1.svn (r65027)
> :~ > r.to.vect input=raster_tty output=vector_tty type=area
> Extracting areas...
> 100%
> Writing areas...
> 100%
> Building topology for vector map <vector_tty at assessment>...
> Registering primitives...
> Killed0000
> what does this mean?
> :~ > v.build vector_tty
> WARNING: Coor file of vector map <vector_tty at assessment> is larger than it
> should be (2403996039 bytes excess)
> Killed0000
> Question about "larger that it should be": What is this limitation? I
> guess is related to the specs of my laptop?
This just means that topology has not been built correctly, which is
probably due to some memory issues.
See also https://trac.osgeo.org/grass/ticket/2045.
One option mentioned in this report is to set GRASS_VECTOR_LOWMEM before
running r.to.vect in order to limit memory usage.
Moritz
