[GRASS-user] GRASS-7svn: Specify wxPython Version
Rich Shepard
rshepard at appl-ecosys.com
Tue Aug 11 10:54:41 PDT 2015
On Sun, 2 Aug 2015, Glynn Clements wrote:
> As for why the wxPython check fails, I would assume that it's something
> specific to your particular installation.
Glynn,
I suspected that the issue is related to having two wxPython versions
installed here. The build problem arose only after I installed 2.8.12 when I
discovered an application that required that version rather than 3.0.2.
Because I've no current project requiring spatial analyses I'll drop the
issue. When I again need GRASS I'll find the cause of the problem when
building from the svn repository.
Thanks,
Rich
