[GRASS-user] Run grass console from a cronjob
Andrea Peri aperi2007 at gmail.com
Wed Aug 26 07:47:08 PDT 2015
Hi, thx for reply.
I guess yes.
I have some relative path, but my first
line in bash is a
" cd /home/--path-to-grass-position "
to set the script in the right position in filesystem.
Also in the script I set these env vars.
  export HOME=/home/path-to-home
  export USER=the_user
  export GROUP=the_group
to the right user and group for grass
A.
2015-08-26 16:38 GMT+02:00 Blumentrath, Stefan <Stefan.Blumentrath at nina.no>:
> Hi,
> Did you provide full paths?
> E.g. "~/my.tif" would not work for cronjobs, you would have to use "/home/user/my.tif" instead.
> Not sure if also the path to the command to execute has to be complete (e.g. /bin/grass70 ...)...
> Cheers
> Stefan
> -----Original Message-----
> From: grass-user-bounces at lists.osgeo.org [mailto:grass-user-bounces at lists.osgeo.org] On Behalf Of Andrea Peri
> Sent: 26. august 2015 16:27
> To: GRASS user list <grass-user at lists.osgeo.org>
> Subject: [GRASS-user] Run grass console from a cronjob
> Hi,
> I'm try to run a grass session from a cronjob The cron execut a bash script where I try to execute
> grass70 -text -c /path-to-geotiff/file.tif -e /grassdata/mapset_location
> If I try the bash script from a console it run good and without any problem.
> Bu if I try to execute the script from a crontab.
> It stop to execute when try to do:
> Is the grass suitable for a cronjob ?
> Thx,
> Andrea Peri
> qwerty àèìòù
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Andrea Peri
qwerty àèìòù
