[GRASS-user] attempt to define a smaller region
Helmut Kudrnovsky
hellik at web.de
Mon Dec 14 05:46:49 PST 2015
jamaas wrote
> I'm a beginner with GRASS, running newest version 7.0.2 on Ubuntu Linux
> 14.04.
> I'm attempting to create a new smaller region, and change the resolution
> to something slightly larger. For some reason the map I get in the GUI
> display window is very detailed however when I try to set a new region
> using g.region it tells me that there is no detail to do it.
> Apologies for all of the detail.
> - This is working with raster maps from the UK ordinance survey (OS)
> system
> - Originally downloaded four individual raster maps from OS is a sort of
> .asc format
> - Then converted them to ARCGIS format using ARCGIS
> - Then combined them into one raster using mosiac to raster, then
> converted back to .asc
> - I've now imported the .asc raster into GRASS and it looks fine, lots of
> detail but I want try to do some hydrologic modelling using TOPMODEL so
> need to produce and topidx file, but before that I want to get a smaller
> region
> -when I attempt to get a smaller region using g.region I get an invalid
> input error.
> -when I look at the raster info using g.region -p, there is almost no
> information
> (Mon Dec 14 11:36:09 2015)
> g.region -p
> projection: 99 (Transverse Mercator)
> zone: 0
> datum: osgb36
> ellipsoid: airy
> north: 1
> south: 0
> west: 0
> east: 1
> nsres: 1
> ewres: 1
> rows: 1
> cols: 1
> cells: 1
> (Mon Dec 14 11:36:09 2015) Command finished (0 sec)
> Something doesn't add up, the information must be in the raster because I
> can see it, any suggestions as to what I've done wrong or how to extract
> the correct region using UK british national grid references?
> Thanks for any suggestions pointing me in the right direction.
adjust the region to your raster, e.g.
g.region -a raster=elevation at PERMANENT align=elevation at PERMANENT
g.repion -p to show the region settings
then digitize a vector polygon for the region of your intereset, then do
g.region -a raster=elevation at PERMANENT vector=yourvector
to shrink your region to the area of your interest
HTH
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/attempt-to-define-a-smaller-region-tp5241216p5241220.html
Sent from the Grass - Users mailing list archive at Nabble.com.
