[GRASS-user] problem addon v.in.ply with grass 7 on ubuntu 14.04
Markus Neteler neteler at osgeo.org
Fri Jun 5 07:15:16 PDT 2015
On Fri, Jun 5, 2015 at 4:05 PM, Carmine Massarelli
<carmine.massarelli at ba.irsa.cnr.it> wrote:
> Hello,
> if i use   g.extension -s extension=v.in.ply   i receive the error
> D1/5: grass.script.core.start_command(): g.message -e
> message=Unable to create '/usr/lib/grass70/docs/rest':
> [Errno 13] Permission denied: '/usr/lib/grass70/docs/rest'
> D1/5: G_set_program_name(): g.message
> D2/5: G_file_name(): path =
> /media/massarelli/sdb/Mappe/GRASS/Statte/PERMANENT
> ERROR: Unable to create '/usr/lib/grass70/docs/rest': [Errno 13] Permission
I think that the "rest" directory should not be generated at all.
Looks like a bug to me (strange that nobody else reported it so far AFAIK).
The workaround is to generate it manually now but I would prefer to
get the issue solved.
Markus
