[GRASS-user] R: wxGUI Cartographic Composer (GRASS 7.0 for Windows)
Aldo CLERICI
aldo.clerici at unipr.it
Mon Oct 12 03:46:50 PDT 2015
Anna
Yes, I use the Windows version of GRASS7.0.
The results are correct in .ps and .pdf output. Only in the Preview the raster map is not displayed.
As regards legend, scale, north arrow and text, they are displayed sometimes, but I’m not able to reproduce when and why.
A. Clerici
Da: Anna Petrášová [mailto:kratochanna at gmail.com]
Inviato: sabato 10 ottobre 2015 17:26
A: Aldo CLERICI
Cc: grass-user at lists.osgeo.org
Oggetto: Re: [GRASS-user] wxGUI Cartographic Composer (GRASS 7.0 for Windows)
On Sat, Oct 10, 2015 at 6:40 AM, Aldo CLERICI <aldo.clerici at unipr.it<mailto:aldo.clerici at unipr.it>> wrote:
Dear all,
when I try to display in Preview mode the maps, legend, north arrow, scale and text inserted and displayed in a frame in Draft mode, only the vector maps are displayed.
Is this a bug?
In the text file with mapping instructions, the instructions for the objects not displayed seem correctly reported.
do you use Windows? I noticed this problem on this platform, but I haven't investigated yet. The problem is that the underlying module ps.map creates PostScript file which is difficult to convert into png - we use Python Imaging Library which uses Ghostscript - so the problem with rendering is somewhere there. If you export Postscript file, or PDF file, do you see the result correctly?
Anna
Thanks in advance
A. Clerici
grass-user mailing list
grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151012/a612dfcc/attachment.html>
