[GRASS-user] Problems with r.basin
battaglia.enzo at tiscali.it
Mon Sep 28 00:07:18 PDT 2015
Hi all,
I'm running into problems with r.basin (Grass 7.0 in Ubuntu
14.04 lts).
I use:
_"__g.region -p -a raster= align="_
_"r.basin -a
--overwrite map= prefix=out coordinates=x0,y0 dir=/home/usr/
threshold=200"_
It works fine when I use the GRASS GIS sample data
"North Carolina". Using the data I'm working on I receive instead this
error message:
_Updating database..._
_ 100%_
_1 categories
read from vector map (layer 1)_
_1 records selected from table (layer
1)_
_1 categories read from vector map exist in selection from table_
_1
records updated/inserted (layer 1)_
_Fetching
data..._
_------------------------------_
_An ERROR occurred running
r.basin_
_Please check for error messages above or try with another
pairs of outlet__ __coordinates_
_Removing region definition _"
I tried
different pairs of outlet coordinates_ _without success. Looking at the
results, the problem seems related to the r.stream.extract module which
fails in outputting the rasters related to the stream network (e.g.
out_stream_e, ut_stream_horton etc). All these raster maps show only a
pixel at the outlet snap point position.
If i try the r.stream.extract
module:
_"r.stream.extract --overwrite elevation=
accumulation=
Links:
[1] https://www.indoona.com/
Connetti gratis il mondo con la nuova indoona: hai la chat, le chiamate, le video chiamate e persino le chiamate di gruppo.
E chiami gratis anche i numeri fissi e mobili nel mondo!
Scarica subito l’app Vai su https://www.indoona.com/
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150928/5bb3dc6d/attachment.html>
