[GRASS-user] GRASS at the 12th International Conference on Hydroinformatics
Anna Petrášová
kratochanna at gmail.com
Fri Aug 12 20:21:46 PDT 2016
On Fri, Aug 12, 2016 at 7:09 PM, Laurent C. <lrntct at gmail.com> wrote:
> Hello,
> This message to let you know that I'll give a talk called "A GRASS GIS
> module for 2D superficial flow simulations" at the 12th International
> Conference on Hydroinformatics that will be held from 21 to 26 of
> august in Incheon, Korea. The goal is basically to present Itzï
> (https://www.itzi.org/), a new superficial flow model that uses GRASS
> as a back-end.
> If any other GRASS user will be present at this event, I'll be glad to meet.
> Of course, I'll be happy if anyone give a try at the software and give
> me some feed back.
This looks great. I tried to follow your example in documentation and
it worked, except for a small inconsistency in map names:
v.to.rast input=watershed_out type=point output=bcval use=val value=0
and in the config file you have:
bcval = bcvalue at PERMANENT
(should be bcval)
I will probably test this more later. We should also consider if there
is a way we could distribute it through official addons.
Thank you,
Anna
> Cheers,
> Laurent
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
