[GRASS-user] GRASS at the 12th International Conference on Hydroinformatics
Laurent C.
lrntct at gmail.com
Sat Aug 13 10:09:12 PDT 2016
2016-08-12 22:21 GMT-05:00 Anna Petrášová <kratochanna at gmail.com>:
> On Fri, Aug 12, 2016 at 7:09 PM, Laurent C. <lrntct at gmail.com> wrote:
>> Hello,
>> This message to let you know that I'll give a talk called "A GRASS GIS
>> module for 2D superficial flow simulations" at the 12th International
>> Conference on Hydroinformatics that will be held from 21 to 26 of
>> august in Incheon, Korea. The goal is basically to present Itzï
>> (https://www.itzi.org/), a new superficial flow model that uses GRASS
>> as a back-end.
>> If any other GRASS user will be present at this event, I'll be glad to meet.
>> Of course, I'll be happy if anyone give a try at the software and give
>> me some feed back.
> This looks great. I tried to follow your example in documentation and
> it worked, except for a small inconsistency in map names:
> v.to.rast input=watershed_out type=point output=bcval use=val value=0
> and in the config file you have:
> bcval = bcvalue at PERMANENT
> (should be bcval)
Thanks. I've corrected the manual.
> I will probably test this more later. We should also consider if there
> is a way we could distribute it through official addons.
I've tried but never manage to make it work. See:
https://lists.osgeo.org/pipermail/grass-dev/2016-March/079481.html
https://trac.osgeo.org/grass/ticket/2480
https://trac.osgeo.org/grass/ticket/2968
So I finally decided to make it a Python package and drop g.parser for argparse.
If anyone want to give it another try, It's OK for me.
Laurent
