[GRASS-user] PostgreSQL raster and vector import
patrick s.
patrick_gis at gmx.net
Thu Feb 4 01:44:41 PST 2016
Dear list
In addition to my mail yesterday (see below):
The use of PostGIS might be related to the conversation from octobre
last year
(http://osgeo-org.1560.x6.nabble.com/External-raster-from-PostGIS-td5231932.html),
but it remains unclear to me how to import raster and is not referred to
in the manual.
My current state seems close to the solution:
r.in.gdal in="PG:dbname=psql_local schema=myschema table=reference_map"
out=region_ref -o --o #load into grass
r.external source="PG:dbname=psql_local schema=myschema
table=reference_map" out=region_ref --o -o #link to grass
But both lead to "ERROR: North must be larger than South"
However, I can view the data in QGIS (loading though db-manager) and it
appears to be ok.
Is Error it a problem of gdal, my data or the grass-modules? And how can
I solve it?
Thanks for any help
Patrick
On 03.02.2016 15:48, patrick s. wrote:
> Dear list
> I need some help on importing PostGIS raster with r.in.gdal and schema
> support under v.in.ogr.
> RASTER:
> "r.in.gdal -f" shows support: "PostGISRaster (rw): PostGIS Raster driver"
> But I did not find any example on how to formulate the dsn/input.
> VECTOR:
> Unfortunately there is no hint in the manual of grass70 on how to work
> with schemas (there was one in 64).
> I had a script in grass64 of following syntax, which is still working:
> ISCHEMA=baselayer
> v.in.ogr dsn="PG:dbname=psql_local active_schema=my_dataschema"
> layer=gws_buildings --overwrite
> However, I would like to form this more general as a variable for all
> incoming data, which is not working:
> INPATH="PG:dbname=psql_local active_schema=my_dataschema"
> v.in.ogr in=$INPATH out=bldg_pt layer=gws_buildings --overwrite
> =>ERROR: v.in.ogr: Sorry, <active_schema> is not a valid parameter
> Also the approach described in the manual of grass64 does not work any
> longer
> db.connect driver=pg database=psql_local schema=my_dataschema
> v.in.ogr in=./ out=bldg_pt layer=gws_buildings --overwrite
> =>ERROR: Unable to open data source <./>
> Thanks for any help,
> Patrick
