[GRASS-user] PostgreSQL raster and vector import
patrick s.
patrick_gis at gmx.net
Thu Feb 4 02:11:46 PST 2016
One finding concerning the variable-based pathdefinition to PostgreSQL
with schema (thanks to a collegue).
Maybe of interest for other users.
My problems of Raster-import remains open...
Cheers,Patrick
#works
DBPATH="PG:dbname=psql_local"
v.in.ogr input=$DBPATH out=bldg_pt layer=${ISCHEMA}.gws_buildings
--overwrite
#does not work
INPATH="PG:dbname=psql_local active_schema=baselayer_2000"
v.in.ogr input=$INPATH out=bldg_pt layer=gws_buildings --overwrite
#work
INPATH="PG:dbname=psql_local active_schema=$ISCHEMA"
v.in.ogr "input=$INPATH" out=bldg_pt layer=gws_buildings --overwrite
#NOTE: "in" needs to be quoted or it will not work
On 04.02.2016 10:44, patrick s. wrote:
> Dear list
> In addition to my mail yesterday (see below):
> The use of PostGIS might be related to the conversation from octobre
> last year
> (http://osgeo-org.1560.x6.nabble.com/External-raster-from-PostGIS-td5231932.html),
> but it remains unclear to me how to import raster and is not referred
> to in the manual.
> My current state seems close to the solution:
> r.in.gdal in="PG:dbname=psql_local schema=myschema
> table=reference_map" out=region_ref -o --o #load into grass
> r.external source="PG:dbname=psql_local schema=myschema
> table=reference_map" out=region_ref --o -o #link to grass
> But both lead to "ERROR: North must be larger than South"
> However, I can view the data in QGIS (loading though db-manager) and
> it appears to be ok.
> Is Error it a problem of gdal, my data or the grass-modules? And how
> can I solve it?
> Thanks for any help
> Patrick
> On 03.02.2016 15:48, patrick s. wrote:
>> Dear list
>> I need some help on importing PostGIS raster with r.in.gdal and
>> schema support under v.in.ogr.
>> RASTER:
>> "r.in.gdal -f" shows support: "PostGISRaster (rw): PostGIS Raster
>> driver"
>> But I did not find any example on how to formulate the dsn/input.
>> VECTOR:
>> Unfortunately there is no hint in the manual of grass70 on how to
>> work with schemas (there was one in 64).
>> I had a script in grass64 of following syntax, which is still working:
>> ISCHEMA=baselayer
>> v.in.ogr dsn="PG:dbname=psql_local active_schema=my_dataschema"
>> However, I would like to form this more general as a variable for all
>> incoming data, which is not working:
>> INPATH="PG:dbname=psql_local active_schema=my_dataschema"
>> v.in.ogr in=$INPATH out=bldg_pt layer=gws_buildings --overwrite
>> =>ERROR: v.in.ogr: Sorry, <active_schema> is not a valid parameter
>> Also the approach described in the manual of grass64 does not work
>> any longer
>> db.connect driver=pg database=psql_local schema=my_dataschema
>> v.in.ogr in=./ out=bldg_pt layer=gws_buildings --overwrite
>> =>ERROR: Unable to open data source <./>
>> Thanks for any help,
>> Patrick
