[GRASS-user] Compile and install GRASS GIS 7 on Fedora 23 64 bit
Markus Neteler
neteler at osgeo.org
Sat Feb 13 14:04:00 PST 2016
On Sat, Feb 13, 2016 at 10:57 PM, CARLO CORMIO <carlo.cormio at gmail.com> wrote:
> Hi Markus,
> thank you, also for qgis 2.13 repo for fedora :-)
cheers. I hope so much that they finish my attempt to package G7 for Fedora.
Any packager reading here?
> Il 13/feb/2016 10:23 PM, "Markus Neteler" <neteler at osgeo.org> ha scritto:
> Yes I have that file, but OpenGL support is not installed as I excluded it
> upon configuration (due to errors,
mhh I guess that's needed. Any error you can post?
> maybe coming from the use of nvidia proprietary driver).
> Could it simply be a matter of path to openGL library?
Might be. Note these "configure" parameters:
--with-opengl support OpenGL functionality (default: yes)
--with-opengl-includes=DIRS
--with-opengl-libs=DIRS OpenGL library files are in DIRS
--with-opengl-framework=DIR
>> And, is the content of
>> cd lib/nviz
>> compiled? (try "make" therein)
> Uhm, I don't think. This is what I see in lib/nviz:
> change_view.c draw.c lights.c map_obj.c nvizlib.dox render.c cplanes_obj.c
> exag.c Makefile nviz.c position.c
> Maybe I have to modify Makefile in the row where it looks for OPENGL_X11?
No - configure does that. What happens, when you launch "make" in that
directory?
ciao
Markus
