[GRASS-user] Compile and install GRASS GIS 7 on Fedora 23 64 bit
    CARLO CORMIO
    carlo.cormio at gmail.com
    Sat Feb 13 16:45:52 PST 2016
HI Markus,
I tried to go back to nouveau driver (uninstalling nvidia driver and
reinstalling mesa and x11) and then to install nvidia driver along
with nouveau (without removing or blacklisting, just following nvidia
driver setup procedure).
Before installing nvidia driver again, I did make cleand and make
distclean of grass install and then compiled GRASS GIS 7.0.4svn (after
svn up) again, following the instruction from grasswiki (link in
previous message). Now everything is ok, no OpenGL errors.
And I finally found what was wrong with nviz/3D view ....
The dropdown menu disappear unless I maximize Map Display windows
(maybe it was there also before, without OpenGL, but we will never
Know :-P). Thus, sorry for stealing your time, but maybe this is
something that should be taken into account. Anything that could let
the user know that there are more options in Map Display menu bar.
Isn't there an option in Layer manager menu to run nviz? I could not
find it. And how to run nviz from command line or terminal?
Ciao,
Carlo
>> Maybe I have to modify Makefile in the row where it looks for OPENGL_X11?
> No - configure does that. What happens, when you launch "make" in that
> directory?
> ciao
> Markus
CARLO CORMIO
Progettazione e consulenza ingegneristica
P.IVA 06741170721
Tel. 3287315782
Via delle Murge, 59/A
70124
Bari
