[GRASS-user] Compile and install GRASS GIS 7 on Fedora 23 64 bit
Vaclav Petras wenzeslaus at gmail.com
Sat Feb 13 19:01:26 PST 2016
On Sat, Feb 13, 2016 at 7:45 PM, CARLO CORMIO <carlo.cormio at gmail.com>
wrote:
> And I finally found what was wrong with nviz/3D view ....
> The dropdown menu disappear unless I maximize Map Display windows
> (maybe it was there also before, without OpenGL, but we will never
> Know :-P). Thus, sorry for stealing your time, but maybe this is
> something that should be taken into account. Anything that could let
> the user know that there are more options in Map Display menu bar.
Please see #2799. It is an issue which is really pronounced on Fedora
because of some other issue with that widget in wxPython or underlying
libraries. Feel free to suggest some replacement. I don't have any good
ideas.
> Isn't there an option in Layer manager menu to run nviz?
No, but perhaps there could be if others thinks it is useful. For example
button in Layer Manager toolbar, but I guess the issue will be then a
longer toolbar again.
> I could not
> find it. And how to run nviz from command line or terminal?
The graphical tool cannot be (currently) used outside of the main GUI.
However, there is m.nviz.image for usage in scripts (or command line;
generates images).
https://trac.osgeo.org/grass/ticket/2799
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160213/8e7d3f79/attachment.html>
