[GRASS-user] GRASS GIS 7.03 for Mac OS X, problem with wxPython (missing)
Adam Dershowitz
adershowitz at exponent.com
Tue Mar 15 05:51:54 PDT 2016
Yes, SIP is a new security feature that prevents any applications from
writing to a few key OS paths. I believe that it really is that simple.
(see: https://support.apple.com/en-us/HT204899 )
Which, does beg the questionŠwhy does running GRASS require writes to any
of these folders? That suggests that GRASS is doing something that it
shouldn¹t be doing. Why should it be writing to system folders at all at
runtime?
It is the only application that I have run into that has any problems with
SIP. It would seem that this should be an easy fix. (for example just
use /usr/local instead of /usr, or whatever the problem folder is).
-- Adam
On 3/15/16, 5:20 AM, "Michael Barton" <Michael.Barton at asu.edu> wrote:
>After this problem was discovered 4-6 months ago, we've been working on a
>way to remedy it. We have a basic plan that William has suggested, but it
>takes some time to work out how to implement it. So far, no one has had
>the time needed to do this. It seems solvable with some effort.
>My understanding is that SIP is a new security feature. Disabling it
>leaves the Mac at the same level of security it has under Yosemite.
>Michael
>____________________
>C. Michael Barton
>Director, Center for Social Dynamics & Complexity
>Professor of Anthropology, School of Human Evolution & Social Change
>Head, Graduate Faculty in Complex Adaptive Systems Science
>Arizona State University
>voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
>fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
>www:
>https://urldefense.proofpoint.com/v2/url?u=http-3A__www.public.asu.edu_-7E
>cmbarton&d=CwIGaQ&c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGqXabRLtSzGmh8YEvbco28T
>aiOmWcn6rCn8wM&m=Du-iDnFBgCWnlt2qQbjsC_YSg06yHml6QRl_8z3v6Ks&s=BMSNf4uJ_w2
>ewwUgMTyEGQGU5wecIjrAaBpBY-3ebyA&e= ,
>https://urldefense.proofpoint.com/v2/url?u=http-3A__csdc.asu.edu&d=CwIGaQ&
>c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGqXabRLtSzGmh8YEvbco28TaiOmWcn6rCn8wM&m=D
>u-iDnFBgCWnlt2qQbjsC_YSg06yHml6QRl_8z3v6Ks&s=nYM20vxBK7g_tQPNjML5LWX-szqTa
>83D4p5P1fuat1o&e=
>> On Mar 15, 2016, at 11:00 AM, Rainer M Krug <Rainer at krugs.de> wrote:
>> Adam Dershowitz <adershowitz at exponent.com> writes:
>>> So it looks like this is actually the known problem with System
>>> Integrity Protection. I hate to turn off a security feature, and do
>>> two reboots, to be able to run a single application. Has there been
>>> any progress in getting this fixed?
>> No - I have the feeling that the ones using GRASS on OS X are still
>> avoiding upgrading to El Capitan, and the ones who have are out in the
>> cold. I raised the issue several times already.
>> I slowly really think the best would be to abandon GRASS on OS X and
>> focus on setting up an official docker image which can be used on OS X,
>> Windows and Linux.
>> Please convince me otherwise.
>> Cheers,
>> Rainer
>>> Thanks,
>>> -- Adam
>>> From: Adam Dershowitz <adershowitz at exponent.com>
>>> Date: Monday, March 14, 2016 at 11:21 PM
>>> To: Michael Barton <Michael.Barton at asu.edu>, grass-user grass-user
>>> <grass-user at lists.osgeo.org>
>>> Subject: Re: [GRASS-user] GRASS GIS 7.03 for Mac OS X, problem with
>>> wxPython (missing)
>>> And, I just tried to run 6.4, which I still had installed, and it also
>>> won¹t run, but with a different error:
>>> Python 2.7.10 found.
>>> Cleaning up temporary files ...
>>> Starting GRASS ...
>>> Traceback (most recent call last):
>>> File
>>> "/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/gis_set.py",
>>> line 37, in <module>
>>> from core import globalvar
>>> File
>>>"/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/core/globalvar.
>>>py",
>>> line 74, in <module>
>>> import wx
>>> File
>>> "/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/__init__.py",
>>> line 45, in <module>
>>> from wx._core import *
>>> File
>>> "/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/_core.py",
>>> line 4, in <module>
>>> import _core_
>>> ImportError: dlopen
>>> (/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/_core_.so,
>>> 2): Library not loaded:
>>> /Users/Shared/unix/wxpython-cocoa-lion/lib/libwx_osx_cocoau-3.0.dylib
>>> Referenced from:
>>> Reason: image not found
>>> Error in GUI startup. If necessary, please
>>> report this error to the GRASS developers.
>>> Switching to text mode now.
>>> Hit RETURN to continue...
>>> Has anyone had any luck running GRASS on 10.11 at all?
>>> -- Adam
>>> From: grass-user <grass-user-bounces at lists.osgeo.org> on behalf of
>>> Date: Monday, February 15, 2016 at 3:24 PM
>>> To: grass-user grass-user <grass-user at lists.osgeo.org>
>>> Subject: [GRASS-user] GRASS GIS 7.03 for Mac OS X, problem with
>>> wxPython (missing)
>>> The packaging seems to have gone awry. I've been out of the country
>>> and then sick since returning. Once I get well enough to get to the
>>> office, I'll try and fix this.
>>> Michael
>>> C. Michael Barton
>>> www:
>>>7Ecmbarton&d=CwIGaQ&c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGqXabRLtSzGmh8YEvbc
>>>o28TaiOmWcn6rCn8wM&m=Du-iDnFBgCWnlt2qQbjsC_YSg06yHml6QRl_8z3v6Ks&s=BMSNf
>>>4uJ_w2ewwUgMTyEGQGU5wecIjrAaBpBY-3ebyA&e= ,
>>>Q&c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGqXabRLtSzGmh8YEvbco28TaiOmWcn6rCn8wM
>>>&m=Du-iDnFBgCWnlt2qQbjsC_YSg06yHml6QRl_8z3v6Ks&s=nYM20vxBK7g_tQPNjML5LWX
>>>-szqTa83D4p5P1fuat1o&e=
>>> On Feb 15, 2016, at 12:59 PM, grass-user-request at lists.osgeo.org
>>> wrote:
>>> From: gene <martin.laloux at gmail.com>
>>> wxPython (missing)
>>> Date: February 15, 2016 at 11:55:37 AM MST
>>> To: <grass-user at lists.osgeo.org>
>>> With the 7.0.3 version of GRASS GIS on the Mac (M.Barton)
>>><https://urldefense.proofpoint.com/v2/url?u=http-3A__grassmac.wikidot.co
>>>m_&d=CwIGaQ&c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGqXabRLtSzGmh8YEvbco28TaiOm
>>>Wcn6rCn8wM&m=Du-iDnFBgCWnlt2qQbjsC_YSg06yHml6QRl_8z3v6Ks&s=BLKBXGdNzoj5N
>>>WVFeIdX9twiagfusrChsptuGoEor-A&e= > I can only launch GRASS-7.0.app
>>> (7.0.3) in
>>> text mode.
>>> When I try to launch the App or use g.gui wxpython in the Grass
>>> shell the
>>> error is:
>>> "Launching <wxpython> GUI in the background, please waitŠ
>>> ERROR: wxGUI requires wxPython. No module named wxversion
>>> In the 7.0.2 version, wxPython is installed in
>>> /Applications/GRASS-7.0.app/Contents/MacOS/etc/python (wx,
>>> wxpython and
>>> pyparsing.py and wxversion.py) and it works.
>>> But none of these files/folders exist in the same folder of the
>>> 7.0.3
>>> version
>>> Compilation error ?
>>> The size of the zip files are also different (80.19 and 83.89 for
>>> GRASS 7.01
>>> and GRASS 7.02, 35 .12 for GRASS 7.03)
>>> Many thanks
>>> grass-user mailing list
>>>https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.osgeo.org_mail
>>>man_listinfo_grass-2Duser&d=CwIGaQ&c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGqXa
>>>bRLtSzGmh8YEvbco28TaiOmWcn6rCn8wM&m=Du-iDnFBgCWnlt2qQbjsC_YSg06yHml6QRl_
>>>8z3v6Ks&s=sBt6fkr01Z2DicvtCKZ0pui9SLbC9JKsQfHXN6pMqcA&e=
>> Rainer M. Krug
>> email: Rainer<at>krugs<dot>de
>> PGP: 0x0F52F982
