[GRASS-user] GRASS GIS 7.03 for Mac OS X, problem with wxPython (missing)
Carlos Grohmann carlos.grohmann at gmail.com
Tue Mar 15 06:14:33 PDT 2016
I run GRASS on OSX El Capitan (with SIP disabled). I don't think that
setting up a CLI-only version would be a solution as well. As Rainer said,
other software runs natively (see QGIS) and they don't have any problems
with OSX/SIP. We should look into that.
I don't understand why GRASS is offending SIP. Perhaps we should seek out
for help from others. Maybe Apple itself.
One point is that we need to disable SIP for the binary provided by Michael
Barton, but not if you compile it from source (or using homebrew), so this
could be fixable by changing paths, like Adam suggested. Homebrew uses
/usr/local, why can't we?
best
Carlos
On Tue, Mar 15, 2016 at 9:51 AM, Adam Dershowitz <adershowitz at exponent.com>
wrote:
> Yes, SIP is a new security feature that prevents any applications from
> writing to a few key OS paths.  I believe that it really is that simple.
> (see:  https://support.apple.com/en-us/HT204899 )
> Which, does beg the questionŠwhy does running GRASS require writes to any
> of these folders?  That suggests that GRASS is doing something that it
> shouldn¹t be doing.  Why should it be writing to system folders at all at
> runtime?
> It is the only application that I have run into that has any problems with
> SIP.  It would seem that this should be an easy fix.  (for example just
> use /usr/local instead of /usr, or whatever the problem folder is).
> -- Adam
Prof. Carlos Henrique Grohmann
Institute of Energy and Environment - Univ. of São Paulo, Brazil
- Digital Terrain Analysis | GIS | Remote Sensing -
http://carlosgrohmann.com
http://orcid.org/0000-0001-5073-5572
________________
Can’t stop the signal.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160315/e2629af3/attachment.html>
