[GRASS-user] GRASS GIS 7.03 for Mac OS X, problem with wxPython (missing)
Rainer M Krug
Rainer at krugs.de
Tue Mar 15 06:31:49 PDT 2016
Carlos Grohmann <carlos.grohmann at gmail.com> writes:
> I run GRASS on OSX El Capitan (with SIP disabled). I don't think that
> setting up a CLI-only version would be a solution as well. As Rainer
> said, other software runs natively (see QGIS) and they don't have any
> problems with OSX/SIP. We should look into that.
Absolutely.
> I don't understand why GRASS is offending SIP. Perhaps we should seek
> out for help from others. Maybe Apple itself.
There were some explanations from Michael why this happens on this
list and also possible solutions - I'll see if I can find them...
Here:
| Subject: Re: [GRASS-dev] GRASS on OS X El Capitan - slowly dying or is something happening?
| To: GRASS developers list <grass-dev at lists.osgeo.org>
| Cc: Rainer M Krug <Rainer at krugs.de>, William Kyngesburye <kyngchaos at kyngchaos.com>, Anna Petrášová <kratochanna at gmail.com>, Brian Miles <selimnairb at gmail.com>
| Date: Thu, 21 Jan 2016 19:19:10 +0000
| AFAICT, the binaries I am compiling under Mavericks work with El Capitan IF you turn off System Integrity Protection (to get to the same level of security available in
| Mavericks).
| I have not yet updated to El Capitan because I'm hoping someone can tell me if they can compile GRASS with it. I don't want to get to situation where I can't produce binaries
| for the community. But I would like to upgrade pretty soon.
| There are several things in process right now. William, Brian Miles, and I have talked about how to deal with the SIP problem. William has an idea of why it is a problem.
| Fixing it will require significant change for how dependencies are packaged and referenced. This related to the second thing.
| We've had to compile GRASS with dual 32 bit/64 bit architecture for several years because v. 2.8.x of wxPython is 32 bit and subsequent versions of wxPython did not work well
| or did not work with GRASS. We've started trying again to get GRASS working with 64 bit wxPython 3 and are having some success. (If anyone wants to test a version, please let
| me know and I'll provide a link to a binary). Because we have to package wxPython with GRASS, and the 32/64 bit dual architecture compilation is causing increasing problems,
| we need to solve that.
| If we can get these things worked out, I hope someone can try to compile GRASS with El Capitan and stock Mac Python, etc. to make sure it all works.
Also the Thread "GRASS on OS X El Capitan - slowly dying or is something happening?"
> One point is that we need to disable SIP for the binary provided by
> Michael Barton, but not if you compile it from source (or using
> homebrew), so this could be fixable by changing paths, like Adam
> suggested. Homebrew uses /usr/local, why can't we?
Using /usr/local is also tricky as it needs to be created without SIP -
but afterwards, SIP can be enabled again. (see
http://digitizor.com/install-homebrew-osx-el-capitan/
I actually think that if homebrew is easiewr to make to work, than this
should be the first step.
Cheers,
Rainer
> best
> Carlos
> On Tue, Mar 15, 2016 at 9:51 AM, Adam Dershowitz
> <adershowitz at exponent.com> wrote:
> Yes, SIP is a new security feature that prevents any applications
> from
> writing to a few key OS paths. I believe that it really is that
> simple.
> (see: https://support.apple.com/en-us/HT204899 )
> Which, does beg the questionŠwhy does running GRASS require writes
> to any
> of these folders? That suggests that GRASS is doing something that
> it
> shouldn¹t be doing. Why should it be writing to system folders at
> all at
> runtime?
> It is the only application that I have run into that has any
> problems with
> SIP. It would seem that this should be an easy fix. (for example
> just
> use /usr/local instead of /usr, or whatever the problem folder
> is).
> -- Adam
Rainer M. Krug
email: Rainer<at>krugs<dot>de
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160315/fb75e1d6/attachment.sig>
