[GRASS-user] i.segment.stats memory usage error
    Markus Metz
    markus.metz.giswork at gmail.com
    Wed Nov  2 09:15:05 PDT 2016
On Wed, Nov 2, 2016 at 3:47 PM, Moritz Lennert
<mlennert at club.worldonline.be> wrote:
> On 02/11/16 11:05, James Duffy wrote:
>> I can't register with osgeo to submit a bug as no-one has replied with a
>> 'mantra' for me to do so... what a convoluted bug reporting system!
>> And in your opinion Moritz, does it look like my workflow will not be
>> possible unless I find a 64bit machine with a decent amount of RAM?
> I'm not sure about the necessity of 64bit, but more RAM probably.
> IIUC, all the stats of all the zones are put into memory during the run of
> the module. Maybe a file-based store of the information might be possible
> which would avoid this memory usage, but I'm not sure.
> @MarkusM: could you have a look at this ? See
> https://lists.osgeo.org/pipermail/grass-user/2016-October/075493.html for
> the beginning of the thread. In short: James seems to be hitting memory
> limits of r.univar and I'm wondering out loud whether there is something
> that could be done about this...
As Anna wrote, the -e flag increases memory consumption of r.univar
considerably. A file based approach for extended stats of r.univar is
difficult because the number of values per segment is initially
unknown to r.univar, thus the amount of disk space needed for extended
stats for each segment is unknown.
I would rather use r.univar for standard stats and r.stats.quantile
for extended stats. The options for raster_statistics of
i.segment.stats would then reduce to "min, max, range, mean,
mean_of_abs, stddev, variance, coeff_var, sum, sum_abs", and a new
option, e.g. raster_percentiles could be added, accepting a list of
percentiles which can be directly fed by i.segment.stats to
r.stats.quantile percentiles=<list of percentiles>.
Markus M
