[GRASS-user] map display query and layers
Anna Petrášová
kratochanna at gmail.com
Tue Oct 4 08:29:38 PDT 2016
On Tue, Oct 4, 2016 at 10:48 AM, Dave Roberts <droberts at montana.edu> wrote:
> Dear Moritz and Helmut,
> v.what works perfectly; thanks for that. Sadly, the issue reflects my
> misunderstanding. I thought the map display GUI was calling v.what with
> coordinates extracted by the GUI from the mouse click. I have been talking
> about the map display query tool on wx# all along, so I apologize if I have
> used the wrong vocabulary to describe the problem.
> File PERMANENT/.tmp/hostname/MONITORS/wx0/cmd correctly reflects the
> layer request from d.vect, so it shouldn't be too difficult to get the GUI
> query tool to honor that, but I'm just beginning to dig into GRASS source
> code and I wouldn't want to tackle this yet.
> Thanks, Dave
It should be fairly simple to add. First it has to be changed in
library function vector_what, then in GUI. Please create a ticket for
that.
Anna
> On 10/04/16 06:32, Helmut Kudrnovsky wrote:
>> Dave Roberts wrote
>>> Thanks Helmut, Thanks Anna
>>> I compiled the trunk version, and the map query tool now clearly behaves
>>> differently, but not how I expected
>>> 1) it shows all layers in the map query results, regardless of what
>>> layer (if any) was selected in d.vect
>>> I.e.
>>> d.vect map
>>> d.vect map layer=1
>>> v.vect map layer=2
>>> all have identical results in map query. In addition, specifying layers
>>> that don't exist emits no warning, e.g. d.vect map layer=999
>>> works fine, and behaves the same as any of the d.vect commands above
>>> 2) it highlights selected features in yellow, and the selected features
>>> (areas in my case) reflect layer #1, no matter what layer is requested
>>> in d.vect. I.e. d.vect map layer=2 map queries highlight layer 1.
>>> I had been working on this with a quite complicated imported data set,
>>> so to isolate the behavior more clearly I created the data below
> material deleted to reduce the length
>>>> Fyi
>>>> http://lists.osgeo.org/pipermail/grass-commit/2016-
>>>> October/040536.html
>>>> Anna committed the patch to trunk ; so if may be able to switch to trunk
>>>> for
>>>> compiling, this v.what addition is available there without the need of
>>>> manually patching.
>>>> best regards
>>>> Helmut
>>>> View this message in context:
>>>> http://osgeo-org.1560.x6.nabble.com/map-display-query-and-layers-tp5288830p5289152.html
>>>> Sent from the Grass - Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> grass-user mailing list
>>> grass-user at .osgeo
>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>> AFAIK the map query hasn't been changed by Anna's commit.
>> v. what (https://grass.osgeo.org/grass73/manuals/v.what.html) has a
>> changed
>> behaviour by now reckognizing the specified layer.
>> the same behaviour for the map query may need a separate enhancement
>> ticket.
>> in the meantime would be v.what an alternative?
>> best regards
>> Helmut
>> http://osgeo-org.1560.x6.nabble.com/map-display-query-and-layers-tp5288830p5289199.html
>> grass-user at lists.osgeo.org
