[GRASS-user] boundary vs area in wx0
Helmut Kudrnovsky
hellik at web.de
Wed Oct 12 13:33:02 PDT 2016
Dave Roberts wrote
> I'm having difficulty getting the wx devices to show vector features.
> For example, I have a map called newveg. v.info clearly shows that
> newveg has areas, e.g.
> Number of points: 0 Number of centroids: 38183
> Number of lines: 0 Number of boundaries: 97451
> Number of areas: 38183 Number of islands: 7112
> If I enter
> d.vect newveg
> it doesn't render anything. If I enter
> d.vect newveg type=area
> it doesn't render anything, but if I enter
> d.vect newveg type=boundary
> I get the boundaries. Furthermore, even when it doesn't draw anything,
> the query tool returns information on polygons I can't see.
> Unfortunately, even though
> v.db.connect -p newveg
> says
> Vector map
> <newveg>
> is connected by:
> layer <1/newveg> table
> <newveg>
> in database
> </home/dvrbts/grass/romo_gdb/PERMANENT/sqlite/sqlite.db> through
> driver
> <sqlite>
> with key
> <cat>
> The query tool is returning information on layer 20 that is no longer
> connected to newveg (it was once upon a time).
> I'm confused
> Dave
> GRASS 7.3.svn, Linux magicsam 4.6.2-1-ARCH #1 SMP PREEMPT Wed Jun 8
> 08:40:59 CEST 2016 x86_64 GNU/Linux
tested here with
Number of areas: 989768
rendering takes some time, after finished rendering areas are displayed
without any problem.
try to rebuild topology by eg. v.build map=yourvector
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/boundary-vs-area-in-wx0-tp5290472p5290487.html
Sent from the Grass - Users mailing list archive at Nabble.com.
