[GRASS-user] Problem running i.segment.stats
Moritz Lennert mlennert at club.worldonline.be
Tue Oct 18 08:17:52 PDT 2016
On 18/10/16 14:27, James Duffy wrote:
> Hello,
> I'm using GRASS 7.0.4 on the OSGeoLive pre-built operating system. I
> have installed the addon 'i.segment.stats' to use with my output from
> 'i.segment.uspo'.
> When selecting the 'rasters' input for this tool, I choose the original
> layers that were used to create the segmented map in the first place.
> Upon execution of 'i.segment.stats', i get the following error:
> Element type should be "cell" and not "raster.
The above message is just a warning and should not keep the module from
working. I just fixed this (r69700), so try reinstalling i.segment.stats.
> The tool does not continue and outputs a blank .csv file.
> Any help solving this would be much appreciated.
Could you send us the command line used (you can get that by pushing the
'Copy' button in the GUI of the module or through the command history in
the GUI 'command console')
Moritz
