[GRASS-user] v.edit tool=merge
    Markus Metz
    markus.metz.giswork at gmail.com
    Fri Sep 23 14:11:11 PDT 2016
On Fri, Sep 23, 2016 at 10:27 PM, Vincent Bain <bain at toraval.fr> wrote:
> Le vendredi 23 septembre 2016 à 22:17 +0200, Markus Metz a écrit :
>> At least you got a working solution.
> Yes, thanks !
> working with the same dataset, I ran into several GUI crashes (no
> time/no way to get an error message cause the window shuts up
> immediately, perhaps there's a log file but I don't know where) when
> trying to edit the vector layer. In the source vector file (extracted
> from a blender file, anyway) I purged two double vertices, reimported
> it, then digitizing went fine in the end. It sounds like a zero-length
> line issue again, no ?
Maybe it is a zero-length line issue. You can remove these zero-length
lines with v.clean tool=rmline and check if editing the cleaned vector
 still causes these GUI crashes.
Markus M
