[GRASS-user] v.edit tool=merge
Vincent Bain bain at toraval.fr
Sat Sep 24 09:17:26 PDT 2016
Le vendredi 23 septembre 2016 à 23:11 +0200, Markus Metz a écrit :
> Maybe it is a zero-length line issue. You can remove these zero-length
> lines with v.clean tool=rmline and check if editing the cleaned vector
>  still causes these GUI crashes.
You're right : cleaning the map prior to editing prevents the crash.
Merci!
Vincent.
