[GRASS-user] v.edit tool=merge
Markus Metz
markus.metz.giswork at gmail.com
Sat Sep 24 13:31:20 PDT 2016
On Sat, Sep 24, 2016 at 6:17 PM, Vincent Bain <bain at toraval.fr> wrote:
> Le vendredi 23 septembre 2016 à 23:11 +0200, Markus Metz a écrit :
>> Maybe it is a zero-length line issue. You can remove these zero-length
>> lines with v.clean tool=rmline and check if editing the cleaned vector
>> still causes these GUI crashes.
> You're right : cleaning the map prior to editing prevents the crash.
These zero-length lines should not cause an infinite loop, fixed in
all G7 branches with r69569-71. With these changes, you also need only
one run of v.edit in order to merge all selected lines.
With G64, v.edit tool=merge hangs for me on that zero-length line.
Weird, that G64 can successfully merge these lines for you.
Markus M
