[GRASS-user] v.edit tool=merge
Vincent Bain bain at toraval.fr
Sat Sep 24 23:36:12 PDT 2016
Le samedi 24 septembre 2016 à 22:31 +0200, Markus Metz a écrit :
> These zero-length lines should not cause an infinite loop, fixed in
> all G7 branches with r69569-71. With these changes, you also need only
> one run of v.edit in order to merge all selected lines.
Yep' perfect!
> With G64, v.edit tool=merge hangs for me on that zero-length line.
> Weird, that G64 can successfully merge these lines for you.
well, my last built of 6.4.x release dates back to mid august.
Vincent.
